2004 VW golf for a deck
CC Road Shop
Posted: March 26, 2004 at 12:44 PM / IP Logged
Any suggestions on how to get it done?  It's a double-din, but I can't find a kit for it yet.
jfk51502003
Copper - Posts: 221
Posted: March 26, 2004 at 2:07 PM / IP Logged
99-00-9008...i think...???
forbidden
Platinum - Posts: 5,354
Posted: March 26, 2004 at 2:11 PM / IP Logged
Shouldn't a standard VW pocket work just fine? Me thinks that it would.
Sweekster
Silver - Posts: 481
Posted: March 26, 2004 at 6:05 PM / IP Logged
You should PM Metra Tech (he works for metra) and he can probably find out if they carry it. Or check www.scosche.com or www.bestkits.com . But I think Rob (forbidden) is right. Unless there was a drastic interior redsign for those cars, it should almost be exact to the 2003 model. In which a current kit should be available for it.
Hope that helps
Duane...
If you think you're confused, imagine how you feel.   2004 VW golf for a deck -- posted image.
Bnluis
Silver - Posts: 578
Posted: March 26, 2004 at 7:08 PM / IP Logged
 Metra  makes a pocket design for VW, remove double din radio and install pocket on the bottom. You will also need a plug an antenna adapter.
Pocket 88-00-9008
plug 70-9003
antenna adapter  40-VW53 if car has amplified antenna or 40-VW54 if not
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Metra Tech
Copper - Posts: 125
Posted: March 28, 2004 at 10:15 AM / IP Logged
Thank you Bnluis and you are 100% correct except for the antenna adapter. That is Metra part# 40-EU55. Also, you can use any snap in pocket you have in your bay. At Circuit City, you have the 88-00-9000 Toyota pocket, 80-9003 smart harness and the antenna adapter is special order. You can use a 40-EU10 if your not worried about AM reception which you do carry.
