wiring harness
95neon
Member - Posts: 6
Posted: March 30, 2004 at 9:07 PM / IP Logged
Me and my buddy did a hack install back in the summer before we knew what we were actually doing (yes, i know, im retarded).  anyways, ive just been gettin shops to install my decks, but i now know what i am doing, and i will be getting a new alpine deck soon.  My question is that since i cut off the factory plug, am i fudged or is there another way to get a replacement plug and connect it on?  Im open to other suggestions, however my first choice would be to restore the wirign to the way it was originally.  thanks
I drive a neon...got a problem with that??
Ravendarat
Platinum - Posts: 2,806
Posted: March 30, 2004 at 9:13 PM / IP Logged
check some of the shops around town. Some of them may have plugs that they have cut off cars when customers were to cheap to by the adapter harness. If not then just go find a dodge vehicle at the wreckers and cut the plugs off from inside the veihcle. Most of the dodge vehicles you find are gonna have the same plugs as your neon and most of those vehicles are also going to have the same wire colors as you vehicle. PS most people did stupid stuff like that before. Just dont do that again and you will be forgiven.
superstreet786
Silver - Posts: 339
Posted: March 30, 2004 at 10:58 PM / IP Logged
if i were you id just use some connectors that you can disconnect it if you have to cuz an original plug may be spendy
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
rknj01
Copper - Posts: 59
Posted: March 30, 2004 at 11:36 PM / IP Logged
you can buy a reverse harness at most car audio places, even places like best buy has them. the only down side is that they use standard colors so u would have to test the wires to know whats what
