Connecting speakers
revo1059
Posted: April 02, 2004 at 10:11 PM / IP Logged
How can I tell (by sound?) if I have the wires reveresed on the speakers I have installed. They sound OK but I'm not sure. The wrires werent marked so I took a guess.......
DYohn
Moderator - Posts: 10,741
Posted: April 02, 2004 at 10:41 PM / IP Logged
Use your balance control.  If the volume gets louder as you shift the balance from left to right, then one of them is out of phase with the other.  Switch the wires on ONE of the speakers if this happens.
revo1059
Posted: April 02, 2004 at 10:48 PM / IP Logged
I will try that, however what is BOTH are reversed?
mobile1
Silver - Posts: 479
Posted: April 03, 2004 at 1:19 AM / IP Logged
take a small battery ( 9volt max.) and put one wire on the + and one on -. if the speaker pushes out the polarities are correct. If the speaker moves in, they are reversed.
DYohn
Posted: April 03, 2004 at 9:11 AM / IP Logged
If both are reversed then it doesn't matter.  + and - on speakers does not matter as long as they are all the same.
flatulatta
Silver - Posts: 356
Posted: April 03, 2004 at 9:23 AM / IP Logged
i thought it could make the bass/midbass distorted if they where reversed???...dont know where i heard that from...
DYohn
Posted: April 03, 2004 at 9:39 AM / IP Logged
Nope.  A (standard dynamic) loudspeaker does not care and it has no impact on performance.  In fact, since it is an AC signal, the + and - are switching back and forth all the time during normal operation.  The only reason for + and - labels is so that all speakers in a system can be connected in the same relative polarity.
revo1059
Posted: April 03, 2004 at 10:04 AM / IP Logged
Does it matter if these have crossovers attached to them. They are MB Quart RKC116 and the 4 connectors from the speaker go into a crossover then there are 2 wires coming out. If polarity doesnt matter then I'll just make sure they are all the same.
Thanks for the info!!
DYohn
Posted: April 03, 2004 at 10:38 AM / IP Logged
OK, now you have changed the picture a bit.  Yes, crossovers make a difference.  The crossover is polarity sensitive depending on how it is made, but it should be clearly marked.  The speakers connection to the crossover doesn't matter, just make sure they are all the same.  But the crissiver itself should be + and - marked for the inputs from your head unit.  If it's not... the striped wire is usually negative.
