how many 4ga wires can you get off of 0ga, etc.?
Ketel22
Silver - Posts: 976
Posted: April 05, 2004 at 5:22 PM / IP Logged
whats a general rule of thumb for when you are splitting wire, like how many of a certain gauge can you get off of your feeding wire? (ie. how many 4ga wires can you split off of a 0ga)
Quad L Handyman services
DYohn
Platinum - Posts: 10,741
Posted: April 05, 2004 at 5:40 PM / IP Logged
Just use whatever size is necessary for the equipment you are powering.  The rule of thumb is to simply use the proper gage wire for the total load.  4 AWG is good for up to 150 amps.  1/0 is good for up to 350 amps.  Always use a larger size then the maximum load you expect to carry.  So for example, if you are running three amplifiers, each requiring 100 amps, I'd run one 1/0 from the battery to a distru blaock, and then use three 4 AWG, one for each amp.  And the proper fuses, of course.
Clean Install
Silver - Posts: 446
Posted: April 05, 2004 at 7:38 PM / IP Logged
I dont see a real problem with the way DYohn stated, just use ohms law rms/idle voltage then find out what size wire your needing cause if you are pulling 150amp 10-13 ft I would use 0awg and then split it with 4awg there should be no problem at all.....how many 4ga wires can you get off of 0ga, etc.? -- posted image.
If we learn from each success and
each failure, then we can improve ourselves
