bad ground?
godsegoizhuge
Copper - Posts: 214
Posted: April 09, 2004 at 1:38 PM / IP Logged
Ok, here's the deal. Got an amp/sub installed in an 04 grand am. Well i hooked the turn on lead to the ign. lead and it comes on, but there's a really bad wurring noise. Could this be a bad ground or what?   I tried moving the ground wire, but it still has it. Any suggestions on what i can do to fix this?
customsuburb
Gold - Posts: 1,813
Posted: April 09, 2004 at 2:08 PM / IP Logged
Is your power cable next to your rca cables going to your amp? This can cause interference. I've also heard that sometimes if you use the ign. lead for turn on lead for your amp you get interference. Try jumping a cable directly from your turn on lead terminal on your amp to the power cable going into your amp.
godsegoizhuge
Copper - Posts: 214
Posted: April 09, 2004 at 2:24 PM / IP Logged
I'm using the high input instead of the low level input, also tried jumping a wire from the positive to remote on and it still gets the interference.   This is the 1st time i ever came across a situation like this. Usually i just install the amp running off an aftermarket deck and not the OEM.
forbidden
Platinum - Posts: 5,354
Posted: April 09, 2004 at 2:53 PM / IP Logged
What amp is this? and in what vehicle?
godsegoizhuge
Copper - Posts: 214
Posted: April 09, 2004 at 3:19 PM / IP Logged
it's an spl-1500 watt and it's an 04 grand am.
customsuburb
Gold - Posts: 1,813
Posted: April 09, 2004 at 5:31 PM / IP Logged
Try using an LOC instead of the high level inputs and see if you still get interference.
godsegoizhuge
Copper - Posts: 214
Posted: April 09, 2004 at 6:46 PM / IP Logged
got it finally figured out. just went ahead and used an loc instead and now it works fine.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
