how many dB from 2 13 inch w6's w/ jl 1000/1
framedragger
Copper - Posts: 105
Posted: April 09, 2004 at 3:33 PM / IP Logged
how much dB should i get from 2 13 inch w6's on a jl 1000/1 dont start flamin cuz my choice, i just need a ball park number. also if i were to put 2 xtant subs on that amp (without the w6's) the octagonal shaped 10's what should i hit if i have the right specs
forbidden
Platinum - Posts: 5,354
Posted: April 09, 2004 at 3:36 PM / IP Logged
This will depend on more factors than just the sub. It will depend on the box, the type of vehicle, the cd player, the source material used. Most dual 10" or 12" systems should hit mid 130 db's to start with. It will depend if you are building for a spl system or a sq system.
framedragger
Copper - Posts: 105
Posted: April 09, 2004 at 3:39 PM / IP Logged
well, its in a neon, for one option and an s10 in the other, me and my friend want the jl setup but i was thinkin the 10's also, but everything would be done to specs, and cd players dont effect it that much do they..... and it would either be fiberglass or MDF board
robbie2883
Copper - Posts: 104
Posted: April 09, 2004 at 11:37 PM / IP Logged
Go to www.jlaudio.com and look up the sub. At the bottom of the page for each product is a link for a .pdf file with all the specs for the sub. If box's are built to specs. Then you should be able to go by the db levels on the sheet.
if its jammed force it - if it breaks in the process it needed to be fixed anyway
how many dB from 2 13 inch w6's w/ jl 1000/1  -- posted image.
haemphyst
Platinum - Posts: 5,059
Posted: April 10, 2004 at 12:58 AM / IP Logged
Also, here is a pretty simple way to figure paek spl of a system. Start with the efficiency rating of the woofer at one watt. Let's say 85dB, and a power handling of 300 watts RMS. How many times does one double before you are at (somewhere around) 300? Well, 1,2,4,8,16,32,64,128,256... STOP. That was 8 doublings, right? each doubling of power will give you 3 dB of output, so 8 (doublings) X 3 (dB per doubling) = 24 dB of total gain, at 256 watts. 85+24=109 dB (± about 1 dB for that remaining 44 watts) for one woofer, and if you have two woofers, you will get an additional 3dB for 112dB, continuous. Also, in a vented enclosure, add 3dB, a bandpass enclosure, add 6dB... It is THAT easy... I do want to add, however that these are anechoic calculations, and cabin gain ("free" sound) will add to these numbers, but at different frequencies for different cars... the smaller the car, the higher the peak cabin gain frequency.
framedragger
Copper - Posts: 105
Posted: April 10, 2004 at 6:20 AM / IP Logged
well that pretty  much sums everything lol to a ballpark figure how many dB from 2 13 inch w6's w/ jl 1000/1  -- posted image.thanks a lot
