sub displacement
Ketel22
Silver - Posts: 976
Posted: April 11, 2004 at 8:05 PM / IP Logged
how do you determine the displacement of a sub, i work hard and long to forget my goemetry so please help me.
Quad L Handyman services
stevdart
Platinum - Posts: 5,816
Posted: April 11, 2004 at 8:11 PM / IP Logged
Check the manufacturer's specs.  I read that a standard for 12's was .07 but today's subs are .85 and larger.  What's the sub, Ketel, or are you working on a hypothetical setup?
irhino2
Member - Posts: 28
Posted: April 11, 2004 at 9:35 PM / IP Logged
The manufacturer of the sub should supply what the recommended air space is.  Once you know what the recommended space is, you can find it by mutiplying the width, length, and the height of the internal dimensions.
Rhino - Bringing you only the best in car audio!!
Ketel22
Silver - Posts: 976
Posted: April 11, 2004 at 9:53 PM / IP Logged
i was looking for a kappa perfect 12.1dvc for a friend who wants to build his own box.
audiokid1
Copper - Posts: 146
Posted: April 11, 2004 at 10:59 PM / IP Logged
81.94 square inches for that particular sub
stevdart
Posted: April 12, 2004 at 5:30 AM / IP Logged
square inches??  If that was a typo and meant cubed, it would equal .047cu.ft.  That's a small 10.  Like I said, a 12 is .07, .085 cubic feet.  Check the manufacturer for exact displacement.  They most likely find out displacement  the easiest and most accurate way...that is, actually displace a liquid instead of air and then measure the remaining liquid after the speaker was set in place.
audiokid1
Copper - Posts: 146
Posted: April 12, 2004 at 9:57 AM / IP Logged
My bad, I misread I thought you were asking for the drivers cone area.  Not sure what the hell I was thinking.
