help please
bruno71088
Copper - Posts: 161
Posted: April 16, 2004 at 11:08 PM / IP Logged
i am in desprete need of an amp for my thunder 8000's i found an amp that might fill my need but i do have a question about it. Its a kicker kx600.4 it says 300watts rms x2 when bridged since it a 4 channel amp if u bridge 2 subs it will be 4ohm is that right?
One more thing is that amp worth 190 dollars
ccjustin
Member - Posts: 18
Posted: April 16, 2004 at 11:30 PM / IP Logged
the 8000's are single 4 ohm voice coil. use an mtx 801d or if you can afford a 1501d. and wire them in parallel. those subs will sound very bad off that 4 channel you are describing
bruno71088
Copper - Posts: 161
Posted: April 16, 2004 at 11:36 PM / IP Logged
is that a 2 channel amp because i just looked it up all i saw was mono
Ravendarat
Platinum - Posts: 2,806
Posted: April 17, 2004 at 12:30 AM / IP Logged
8000's are availible in both single and dual 4 ohm voice coils so we need to know which you have to answer your question. And the 600.4 is definatly a 4 channel amp, not 2 channel or mono
bruno71088
Copper - Posts: 161
Posted: April 17, 2004 at 12:40 AM / IP Logged
ok there single vc but it doesnt matter anymore i just bought 2 pioneer 760 watt amps thanks alot for your help
bruno71088
Copper - Posts: 161
Posted: April 17, 2004 at 12:46 AM / IP Logged
oh yeah on more thing if i hook up one of those pioneers to each sub how do you think it will sound. amp is rated at 360x1rms bridged i think it should sound good anyone have any idea?
forbidden
Platinum - Posts: 5,354
Posted: April 17, 2004 at 1:25 AM / IP Logged
Yes, make sure that the subs are 100% completely isolated from each other, no visitation rights, no weekend hook ups, well I hope you get the drift. Each sub must be in it's own enclosure.
bruno71088
Copper - Posts: 161
Posted: April 17, 2004 at 7:39 AM / IP Logged
Actually i already have a box for them its a bandpass with a division in the middle to separate the subs will this be ok?
