94 cadillac head unit installation
cafer
Posted: May 05, 2004 at 1:24 PM / IP Logged
I'm try to connect a Alpine head unit to my 94 cadi concourse can't get  power ant to work or get any spk sound  need help hooking up system  any  installers out there.
carlos fernandez
kgerry
Platinum - Posts: 3,455
Posted: May 05, 2004 at 1:31 PM / IP Logged
did you use a proper Metra or equivalent wiring adapter and plug into the OEM harness?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
kgerry
Posted: May 05, 2004 at 1:34 PM / IP Logged
if you did, connect the blue wire in the plug to the single spade wire ( usually pink ) that previously plugged into the factory radio....
this isnt a BOSE system, is it?
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
cafer
Posted: May 06, 2004 at 6:23 PM / IP Logged
thanx  kgerry  i blew 2 fuses
carlos fernandez
kgerry
Posted: May 06, 2004 at 6:31 PM / IP Logged
that' ll do it.... i always forget to say " check the obvious ".....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
cafer
Posted: May 06, 2004 at 6:43 PM / IP Logged
i'm back  still nothing  would you have a wire diagram for alpine to caddi -or send some directions  1st  time  trying  to do it myself
carlos fernandez
cafer
Posted: May 07, 2004 at 2:29 PM / IP Logged
Monday, October 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
