where am i going wrong? infinty perfect 1
dudek38
Copper - Posts: 250
Posted: May 08, 2004 at 11:04 AM / IP Logged
ok, i have a pioneer mono class d 1000w max amp and a perfect 12dvc in a .88 sealed down fire box lined with polyfill. the boost is down and frequency set right. the sub is wired at 2ohms.
the sub suffers from major overexcursion at high levels. this sub should not do this and i cant get it right. i was expecting it to pound much harder and handle way more. the xmax spec is 14.15 which is high for a sub so sag isnt an issue. what to do, what to do. should i wire it at 8 ohms,is the amp too powerful, what? is it a case where i should try another sub, jl 12w6?
owner of
Motion Marine & Car Audio
the florida keys
boomer_106
Silver - Posts: 710
Posted: May 08, 2004 at 11:42 AM / IP Logged
Have you checked the manufacturers specs for the size of box? .88 sounds a bit small for a 12 inch sub. Im not sure this is your problem but it jumped out at me.
customsuburb
Gold - Posts: 1,813
Posted: May 08, 2004 at 11:46 AM / IP Logged
I don't think this sub is meant to be downfired.
DYohn
Platinum - Posts: 10,741
Posted: May 08, 2004 at 12:54 PM / IP Logged
Infinity Kappa Perfect 12.1 is rated at 350 watts RMS.  Your Pioneer amp can deliver 600 watts RMS into 2 ohms.  You are over-driving the speaker and if yu keep it set up this way will eventually fry the voice coils.  Wire it at 8 ohms and the amp will deliver approximately 150 watts.  It will sound much better and be safer for the sub, although it is not the best match if you are looking for SPL.  0.88 CUFT is fine for a sealed enclosure size.
By the way, when mounting a Kappa Perfect sub in a down-firing configuration, Harmon Kardon (who own Infinity) recomends de-rating the power by about 20%.  In your case, that means limit the power to approximately  280 watts RMS.
dudek38
Copper - Posts: 250
Posted: May 10, 2004 at 6:55 PM / IP Logged
i wired the sub at 8 ohms and its much better. i underestimated the rms power of the pioneer amp, and some others too.
learn something new everyday. im a happy customer.
thanks 12volt
owner of
the florida keys
thapimpfromchi
Silver - Posts: 616
Posted: May 10, 2004 at 7:30 PM / IP Logged
yea, i wouldnt run the kappa down or up. A buddy of mine had some in a box, they sounded great facing back or forward, he faced them up, they sounded like ass. I'm not talkin about the acoustics of the car limiting its ability to hit, im sayin it sounded like sh*t. (excuse my french). It could be the same problem. But, you might wanna try what DY said, cuz when he had it like that, he was giving it 500 watts.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
dudek38
Copper - Posts: 250
Posted: May 10, 2004 at 9:55 PM / IP Logged
no, it sounds fine. it's not as tight as id like, but im very happy. i dont buy the "down or up wont sound good theory." i was putting too much power to it, thats all.
owner of
the florida keys
thapimpfromchi
Silver - Posts: 616
Posted: May 10, 2004 at 10:31 PM / IP Logged
its not really a theory, its numerical fact. some subs cannot be faced up or down, due to the design. However, if you are happy with what you did, more power to ya! enjoy.
