Zero Voltage from EQT Output
Platinum - Posts: 12,488
Posted: September 01, 2002 at 8:01 PM / IP Logged
Have two EQT's that have " 0 " voltage on the output RCA. Everything seems to be fine except that there's no output signal. I have one that has an output signal of about 1.6V and it works properly. Any ideas on what is wrong with the internal workings of the EQT's ??
dirtdr
Member - Posts: 22
Posted: September 02, 2002 at 9:04 PM / IP Logged
Is the PFM modules installed inside... even if not using the subsonic block, there must be a module installed... if it is there, check to see if it is pushed in all the way
crroush
Copper - Posts: 151
Posted: September 02, 2002 at 9:34 PM / IP Logged
I have seen the gain POT burn out and be set to "off", thus giving no out put voltage.
Another way to go is to open it up and trace the signal through the system from input to out put and see what component may be causing you trouble, like if an inline diode/transistor or whatever is bad.  It is a tedius process though, but I have repaired CD players and cellular phones that had oddball parts bad this way.
good luck!
Craig
Posted: September 02, 2002 at 10:18 PM / IP Logged
Thanks for the suggestions. I will try and trace the problems and check the PFM modules to ensure they are fully connected.
crroush
Copper - Posts: 151
Posted: September 03, 2002 at 11:30 AM / IP Logged
Zero Voltage from EQT Output -- posted image.did you fix it Jeff?
Craig
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
