Engine noise/Alternator whine
Manoftools
Copper - Posts: 55
Posted: May 30, 2004 at 12:36 AM / IP Logged
I have a customer coming in tomorrow that says he has engine noise.  When I did the original install I made every precaution to avoid this.  All the basics: signal wires opposite side of car as power, keeping power wire away from belts, used good RCA's.  Anybody got any ideas of something I might have missed.  It is in a 2003 Galant.
italnpimp59
Silver - Posts: 427
Posted: May 30, 2004 at 12:47 AM / IP Logged
did u run the remote with the rca's?  ive seen this cause a problem before.  check your ground, matter of fact, ground it somewhere else just in case ur connection was a little bit loose.  maybe his equiptment is crappy, that can cause it too!
stevdart
Platinum - Posts: 5,816
Posted: May 30, 2004 at 12:48 AM / IP Logged
I hate hearing in advance what a perceived problem is.  I'd rather just look at it at the time and save myself those hours of wondering!  See if he has a sound electrical system under the hood.
Manoftools
Copper - Posts: 55
Posted: May 30, 2004 at 12:50 AM / IP Logged
I ran the remote along with the power wire, and my ground is about as good as it gets.  Also, all of his equipment was brand new... purchased from me, so i hope its good!!!
fredisfound
Copper - Posts: 60
Posted: May 30, 2004 at 1:11 AM / IP Logged
I have had a problem in the lancers with the headunit grounding. The dash grounding is not real good and had to ground the headunit to the chassis of the car to get rid of engine noise.   Check that out.
italnpimp59
Silver - Posts: 427
Posted: May 30, 2004 at 1:30 AM / IP Logged
yea i forgot about that, mitsubishi has a funny grounding system.  run a ground directly to chassis from the headunit, see if that works.
licensedtoquill
Member - Posts: 7
Posted: May 30, 2004 at 7:27 AM / IP Logged
I have got what sounds like an alternator whine but it only comes on badly when the cassette unit of my in dash Sony is being used and then it is only really bad when I turn the air conditioning on. And unfortunately the idiot installer put the tweeters at the top of the door posts about three inches from my ear for maximum impact of any such noise. (and then couldn't figure out how to get rid of the noise so threw his hands up in despair, leaving me to figure it out)
This is a 1984 Silver Spur and he put the amp in the deisgnated position directly next to the battery in a cavity below the floor of the trunk in my car which might be making it worse. (but I suspect that the problem could be cured and isn't with the positioning of the cables or of the amp, given that everyone else seems to use that positioning and routing for their installation)
In desperation I tried putting a Pyramid NS21 20 amp high suppressor Isolation transformer just between the phono imput and the amp, not being sure what such an item would do to the quality of the sound, which is pretty lousy in any event with practically no bass whatsoever(Pioneer amp). But for the moment I am trying to get rid of the whining noise prior to seeing what I can do about the actual sound quality. I am faintly aware from my HiFi days that you shouldn't put anything in the line between the sound source and the amplifier which is some indication of how desperate I am to get rid of this noise. And in any event I had an AudioCap subwoofer which I kept below the seat half way between the head unit and the amp which I thought would take care of the bass before it stopped working so I am trying to find somewhere to get it repaired at reasonable cost at the moment (not easy in New York City where no one expects anything like this to be repaired any more: But its low flat design SEEMS to be the only unit/placing of a subwoofer I can utilise so I will worry about THAT later as well)
Is there some trick to using these suppressors? Must it be nowhere near the amp or nowhere near the battery or something or is this just a lousy suppressor (or a faulty one)? The instructions don't say anything about it needing to be grounded or anything so I tried just hanging it loose on the floor of the trunk to see what effect it had on reducing the whine and as I say it made the sound completely unbearable.
Licensed to Quill
"He that would keep a secret Must keep it secret
That he hath a secret to keep"
stevdart
Posted: May 30, 2004 at 10:59 AM / IP Logged
Engine noise/Alternator whine -- posted image.
PAC products may have the solution you need...maybe someone reading this forum will notice your car is a Rolls Royce and will have knowlede of its grounding system.  I suspect it may be common ground with some newer type floating ground equipment installed.  Your post is at the tail end of a thread that identifies the car as a Mitsubishi, so it may not be as widely seen as it would if you had started a new thread titled 'Silver Spur alternator whine suppression'.
There are new flat subwoofer drivers available, too, and could be one to replace the old one you can't get repaired.  There was a thread two or three weeks back that addressed those, that I recall.
Manoftools
Copper - Posts: 55
Posted: May 30, 2004 at 10:36 PM / IP Logged
After going through the entire install, I could only slightly reduce the engine noise.  I am going to try some inline RCA filters, does anyone know of some decent filters that may solve my problem.  The cheaper the better because I am taking the hit on them to avoid a full return of the system.
Platinum - Posts: 12,488
Posted: May 31, 2004 at 12:26 AM / IP Logged
Does the RCA wires that you installed have the grounding wire attached to it ?  If so, ground this wire and it will help.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
