Amp Recomendations
ravenndude
Silver - Posts: 250
Posted: May 30, 2004 at 11:46 AM / IP Logged
I'm looking for a class D amp that will be able to push about 300watts RMS at 8ohms. Should i just look for a class D amp that pushes 600watts at 4ohms?
I'm partial to Fosgate, MTX, JL...
DYohn
Platinum - Posts: 10,741
Posted: May 30, 2004 at 11:58 AM / IP Logged
In general that would be correct.
stevdart
Platinum - Posts: 5,816
Posted: May 30, 2004 at 12:17 PM / IP Logged
That will be a large (read expensive) amp.  A major benefit of a classD amp is the ability to go to a 2 ohm load.  With what you are wanting to do, you will have less in cost by using a 2 channel amp.  Same general guidelines as noted above.
gregfocker77521
Copper - Posts: 69
Posted: May 30, 2004 at 12:19 PM / IP Logged
look at JL audio 450/4 amp, here are the specs
Available: Now
 Channels 1&2 :
stereo mode:
150 W RMS x 2 @ 1.5 ohm – 4 ohm
(11 – 14.5V)
bridged mode:
300 W RMS x 1 @ 3 ohm – 8 ohm
(11 – 14.5V)
 Channels 3&4:
stereo mode:
75 W RMS x 2 @ 1.5 ohm – 4 ohm
(11 – 14.5V)
bridged mode:
150 W RMS x 1 @ 3 ohm – 8 ohm
(11 – 14.5V)
 THD at Rated Power:
<0.03% @ 4 ohm (All Channels)
 S/N Ratio* (All Channels):
>108.5 dB below rated power
 Frequency Response (All Channels):
5 Hz-30 KHz (+0, -1dB)
 Damping Factor (All Channels):
>200 @ 4 ohm/50 Hz
 Slew Rate (All Channels):
±25 V / µS @ 4 ohm per ch.
 Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
 Dimensions:
19.7"L x 9.25"W x 2.36"H
(500 mm x 235 mm x 60 mm)
DYohn
Posted: May 30, 2004 at 12:24 PM / IP Logged
Actually I'd tend to agree more with stevdart that a 2-channel amp rated at 300 watts per channel into 4-ohms would make a better choice than a 4-channel amp.  Bridging 2-channels would be cleaner than bridging 4-channels.
customsuburb
Gold - Posts: 1,813
Posted: May 30, 2004 at 1:57 PM / IP Logged
Use JL's 300/2 instead. Its has the same specs as the 300/4 except its a 2 channel amp instead.
stingercaraudio
Member - Posts: 21
Posted: May 30, 2004 at 4:48 PM / IP Logged
Pick a 2 channel that's rated at 150 x 2 at 4 ohms, that will give you 300 at 8 ohm bridge. JL or not it should work out just fine. Whut are you trying to power?
DYohn
Posted: May 30, 2004 at 4:52 PM / IP Logged
Actually, 150 watts @ 4-ohms stereo will give you 150 watts @ 8-ohms bridged mono.
forbidden
Platinum - Posts: 5,354
Posted: May 30, 2004 at 10:34 PM / IP Logged
Dyohn, take a breather dude, you must have had a long day. My day off. Amp Recomendations -- posted image.
300w x 2 @ 2 ohm = 600w x 1 @ 4 ohm
150w x 2 @ 4 ohm = 600w x 1 @ 4 ohm
Thus a single 8 ohm driver in mono will indeed be 300w.
DYohn
Posted: May 31, 2004 at 10:10 AM / IP Logged
Oops.  I could lie and say I was posting the value per woofer in a dual setup and look really clever... but the truth is closer to too much Napa Valley wine while posting...  Amp Recomendations -- posted image.  Thanks for the catch.
An amp sould deliver approximately 1/2 its rated output at 4-ohms into an 8-ohm load.   Math, duh.
