Speaker problems on 1989 Bronco
Lazerbeam
Posted: May 31, 2004 at 12:13 PM / IP Logged
Problem is that I can only get one speaker the right front to fire. Have followed the hookup wiring diagram from this site and only get sound out of that speaker. What am I missing here?  Have tried connecting that set of speaker wires (front right) to all other speaker outputs on stereo unit and I get sound. But connecting the designated speaker wires to those outputs gets zilch. Any help or ideas appreciated. Thanks in advance. -- Lazerbeam
DYohn
Platinum - Posts: 10,741
Posted: May 31, 2004 at 12:28 PM / IP Logged
Sounds like the OEM speaker wires in the truck are bad.  Do you get continuity readings through the speaker wires with an ohm meter?
bardessono
Posted: June 30, 2004 at 1:26 PM / IP Logged
I've the same problem with a '89 Ford Bronco.  Would you share the out-come of this delima?  I'm not sure if I should
1) replace the speakers (Right Front is ony one working very well).
2) Replace wiring
3) do both.
jpb
forbidden
Platinum - Posts: 5,354
Posted: June 30, 2004 at 1:41 PM / IP Logged
Check for continuity on the factory speaker wires and check to see if any of them are going to ground. If they are they need to be replaced. If the speakers are shot, don't expect an sound as well. Make sure the balance and fader are set properly on the cd player.
archemedes
Copper - Posts: 172
Posted: June 30, 2004 at 1:46 PM / IP Logged
go to the speaker location and run a temporary test wire to see if it's the speaker or wire, if it still doesn't work swap in a known good speaker to also check the wireing (you could do a continuity check, but the speaker will work as well)
kgerry
Platinum - Posts: 3,455
Posted: June 30, 2004 at 3:59 PM / IP Logged
you didnt happen to replace the radio with a different Ford radio did you?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
bardessono
Posted: June 30, 2004 at 4:19 PM / IP Logged
Yes I did.  The replacement radio was in a '95 Ford Aerostar Van we own.  This radio was in good working condition (was replaced with a Stereo CD player).  The two (bronco and aerostar) are same (in apperance, size, name and faceplate). The part id's are the same for both rear plugs and fit fine.Prior to changing radios, the speakers were faint, but not as much as now
Thanks!
jpb
kgerry
Posted: June 30, 2004 at 5:07 PM / IP Logged
thats the problem...the Aerostar radios use a different radio pin out configuration because of the RSA ( Rear Seat Audio ) module and is not compatible with other vehicles.... at least not without a fair bit of rewiring
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
bardessono
Posted: June 30, 2004 at 5:13 PM / IP Logged
Do you know of a adapter for this (or where to get one)?
Thanks!
jpb
kgerry
Posted: June 30, 2004 at 5:27 PM / IP Logged
they never made one... i can give you a tip that has worked for me in the past...but i'm doing it from memory so if i'm wrong dont jump on me with both boots.... the end connector has the speaker wires on it, the second wire down is the common ground for all the speakers...you have to cut the other 3 speaker ground wires behind the plug and connect them all to this common ground wire..the speaker positives stay as is... let me know if this worked...if it didnt i'll dig out my book of wisdom and look up the schematic i drew years ago to overcome this situation.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
