97 Tahoe Speaker Wiring
ezfilez
Posted: June 02, 2004 at 3:59 PM / IP Logged
I can not seem to find the speakers wires that come from the back 2 doors .. I had no problem with the front doors and the rear Speakers .. Keep in mind this is a 4 door and im trying to find the wires that come from the back 2 doors .. I cant seem to find them where the radio installs
Thank you
customsuburb
Gold - Posts: 1,813
Posted: June 02, 2004 at 4:04 PM / IP Logged
There is a small factory amp for them below the dash to the right of the steering column I think. It's just a small (about 3" by 1" or so) grey box with a heat sink on one of the sides. I'm not sure how to activate the amp though...
Chad7n7
Silver - Posts: 408
Posted: June 02, 2004 at 6:33 PM / IP Logged
Best solution that I have found for that problem(and probably quicker) is to run new wires to them from your HU.
chevyman26
Copper - Posts: 227
Posted: June 02, 2004 at 9:02 PM / IP Logged
There is a pink wire on the factory wire harness- hook your remote wire up to it. It will work. I have a '99 Tahoe and had the same problem. If you have any problems finding it I will copy the post that was written to me.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
