wiring subs to amp
leevander
Member - Posts: 20
Posted: June 03, 2004 at 6:08 AM / IP Logged
i have to 10" subs and a 2 channel amp.  the enclosure has two plugs on each side of the subwoofers.  do i run a positive and negative from each subwoofer or can i bridge the wires to the amp from one plug?  will that make both speakers play?
bj hargrove
pimpincavy
Silver - Posts: 880
Posted: June 03, 2004 at 7:02 AM / IP Logged
It sounds like the easiest thing to do would be to simply connect one sub to one channel, and one sub to the other.
silversi17
Member - Posts: 25
Posted: June 05, 2004 at 4:37 AM / IP Logged
if the subs are 4ohm run them to each separate channel, if they are 8 ohm, you should bridge them.  Or if your amp can handle 2ohms, then you can bridge the 4 ohm subs too depending on how much power the subs can handle and how much the amp is going to put out
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
