subs 6ohms amps 4ohms
jussam
Copper - Posts: 78
Posted: June 03, 2004 at 8:33 AM / IP Logged
i'm installing two 12" dual voice subs 1000w @ 6ohms and two 6x8 250w @4ohms in parallel total 1.2 ohms
my amps rating is 1600w @ 2ohms
1000w @ 4ohms ,
500w x 1rms into 4ohms  20hz-100hz
900w x 1 rmsinto 2 ohms 20hz-100hz
will this amp be ok to push subs and speakers if wire this way
stevdart
Platinum - Posts: 5,816
Posted: June 03, 2004 at 8:47 AM / IP Logged
You can run just the subs with a mono amp.  Use a stereo 2 channel amp for the 6x8's.  Post up models for the amp and subs, pls.
jussam
Copper - Posts: 78
Posted: June 03, 2004 at 9:01 AM / IP Logged
amp is a sony xm-ds1000p5 1600w mono
subs are audiobahn alum12q 1000w dvc 6ohms
stevdart
Posted: June 03, 2004 at 9:33 AM / IP Logged
You must be trying to lower the total impedence by adding the 6x 8's in with the subs.  That is not the way to go.  You have equipment that is ill-matched.  The amp is rated to 2 ohms, not to 1.5.  You will have to wire the subs in series for 12 ohms each, and connect to amp for a 6 ohm load, giving the subs maybe 350 watts combined.
DVC 6 ohm subs should be matched with an amp rated to 1 ohm, when you're using two of them.
jussam
Copper - Posts: 78
Posted: June 03, 2004 at 9:45 AM / IP Logged
yes i no it's an ill match i was trying to install it temp,until my audiobahn amp comes in so i should just wait 2weeks till it comes in
thanks for the advice
jussam
Copper - Posts: 78
Posted: June 03, 2004 at 10:30 AM / IP Logged
stevdart will this work before ordering
  • 2 Channel 4 Ohm RMS 310 x 2 Channel / 2 Ohm RMS 370 x 2
  • 1600 Bridged Max
  • 740 Mono RMS
  • Full Selectable Crossover Hi/Full/Low
  • Three Way Protection Circuit
  • Tri-Mode Capable
  • 2ohm Stable Stereo
  • Full Mosfet Power Supply
  • System Distress Indicator
  • High/Low Level inputs With Floating Ground
  • 4 Gauge Power/Ground Connection
  • Gold plated RCA Connectors
  • Line output
  • PWM Circuitry
  • Variable Low Pass 40Hz-120Hz
  • Variable Hi Pass 150Hz-1.5Khz
  • 18dB Bass Boost @ 40Hz.
  • Frequency Response: 10Hz to 30Khz
  • S/N Ratio:97 db
  • THD: 0.02%
  • jussam
    Copper - Posts: 78
    Posted: June 03, 2004 at 10:33 AM / IP Logged
    without the 6x8 install
    stevdart
    Posted: June 03, 2004 at 12:10 PM / IP Logged
    With your DVC subs wired in parallel for 3 ohms each, you could connect a sub to each channel of that amp.  This amp provides more power than the other one you listed, and should drive those speakers with some gusto.
    jussam
    Copper - Posts: 78
    Posted: June 03, 2004 at 1:48 PM / IP Logged
    thanks for your help
    Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
