ANL fuse vs AGU fuse
bruno71088
Copper - Posts: 161
Posted: June 15, 2004 at 3:52 PM / IP Logged
my fuse keeps busting and its probably because it was only 50 amps and then i tried a 60 it blew too. When i was looking to buy more i saw the agu like mine seem to not even come close to the power of anl is this true or am i just not looking hard enough? Before i buy more i was wondering if i should just get a anl fuse holder and just get anl fuses from now on, any opinions
kgerry
Platinum - Posts: 3,455
Posted: June 15, 2004 at 4:07 PM / IP Logged
AGU's are only rated to 60 amps ( although one company makes 80's )  ANL's start at 60 and go to about 250 amps
you just have to chose the proper fuse/fuseholder based on your application
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
bruno71088
Copper - Posts: 161
Posted: June 15, 2004 at 4:10 PM / IP Logged
actually ive seen agu at 100 and i believe i may have seen higher not sure about higher though
kgerry
Posted: June 15, 2004 at 4:22 PM / IP Logged
strange.. i've never seen them that high... not surprising since the AGU fuse holders are only rated to 60 amps of current...at which point they start to melt...   whereas most GOOD quality ANL holders are made from Bakelite or a similar composite which can withstand far greater heat requirements
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
bruno71088
Copper - Posts: 161
Posted: June 15, 2004 at 4:27 PM / IP Logged
do you think it would be better for me to go ahead and just get a ew fuse holder for anl fuses
kgerry
Posted: June 15, 2004 at 5:55 PM / IP Logged
actually i would want to ascertain what the current draw for your application SHOULD be, then see if you are under fusing it or if you have a problem somewhere... dont just bump the fuse up blindly without doing some diagnosis.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
bruno71088
Copper - Posts: 161
Posted: June 15, 2004 at 6:27 PM / IP Logged
im almost completely positive that the fuse was to weak because i have 2 pioneer amps 760 watts each and a rf 401s then i unhooked the 401s and hooked up a power800a2 in its place and thats y it blew so i dont see any other reason unless the 800a2 wasnt good since it wasnt mine i was just testing it
Ketel22
Silver - Posts: 976
Posted: June 15, 2004 at 6:44 PM / IP Logged
im guessing you have a 4ga wiring going from the battery to the amps. if so you should probally have near a 100amp fuse.
Quad L Handyman services
bruno71088
Copper - Posts: 161
Posted: June 15, 2004 at 7:07 PM / IP Logged
if i use 150 on a anl fuse would that be too much or is that ok
Ravendarat
Platinum - Posts: 2,806
Posted: June 15, 2004 at 10:29 PM / IP Logged
If you are gonna run all those amps you should be replacing your power wire or at least running a dedicated 4 gauge wire for the 800.2.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
