need help hooking up amp to sub
morebassplease
Posted: June 30, 2004 at 5:59 PM / IP Logged
hi
i have 2 rockford punch P3001 amps that i bought a few months ago. how do i hook these up to 2 12" solo-baric L5's and is there any way i can hook up the remote bass knob so that it controlls both amps? thanks a lot.
italnpimp59
Silver - Posts: 427
Posted: June 30, 2004 at 8:24 PM / IP Logged
does the amps have a rca line output?  if so, chain the rca's from one amp to another and the bass knob goes into the first amp, that way it controlls the bass going to both amps
jussam
Copper - Posts: 78
Posted: July 01, 2004 at 7:49 AM / IP Logged
2-alpine amp mrv-f545 4ch amp
polk audio 6 1/2 frontdoor w/alpine center speaker
polk audio 6 1/2 rear w/8"polk sub
2-12" alpine X type sub
2-alpine mdr-1005 amps
Clean Install
Silver - Posts: 446
Posted: July 01, 2004 at 9:24 AM / IP Logged
what are your ohm subs do you have?
did you not recieve the instruction manual?
it will tell you the lowest ohm load for the channels
If we learn from each success and
each failure, then we can improve ourselves
jussam
Copper - Posts: 78
Posted: July 01, 2004 at 1:16 PM / IP Logged
also you can take neg from (amp 1 )speaker  terminal  to neg of (amp 2  )speaker  teminal and pos of amp 1 terminal to sub pos and pos of amp 2  teminal to sub neg  if you go this way then leave the subs parallel for 2ohm load then wire in series to amp  for a 4ohm load  for two subs
amp1 would be your master amp 2 would be slave
DYohn
Platinum - Posts: 10,741
Posted: July 01, 2004 at 2:24 PM / IP Logged
Ah, no, you cannot do that with most amps.
Clean Install
Silver - Posts: 446
Posted: July 01, 2004 at 3:49 PM / IP Logged
No you can not wire the amps in that way
morebassplease
Posted: July 01, 2004 at 9:48 PM / IP Logged
thanks a lot for the help guys.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
