splitting the accessory wire
King_Midas
Member - Posts: 35
Posted: July 12, 2004 at 9:28 AM / IP Logged
I'm trying to split the accessory wire (power antenna) on my 97 civic but it doesn't seem to be working. from what I understand it works by sending a small pulse of electricity. wlll splitting it into 3 wires affect this? I recently split it into 3 wires interrupted by switches. therefore I thought that when the circut was completed they would work. anyways take a look at the picture and let me know if I did something wrongsplitting the accessory wire -- posted image.
Ketel22
Silver - Posts: 976
Posted: July 12, 2004 at 9:53 AM / IP Logged
depending on your head unit, the power antenna may only recieve signal when the fm or am radio is on..you really should just run the remotes straight to the battery and use your switches that way...
Quad L Handyman services
King_Midas
Member - Posts: 35
Posted: July 12, 2004 at 12:28 PM / IP Logged
I know but I was using the same head unit and one of the same subs before I added the switches.
xtreamcc
Silver - Posts: 467
Posted: July 12, 2004 at 3:00 PM / IP Logged
your not gona wanna run that off the power antenna as it is not used for the remote. You can do a switch layout like the one you drew from the remote turn on to the head unit just fine, but from the power antenna? That sounds like it wouldn't work well to me.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
jgarcellano
Member - Posts: 7
Posted: July 12, 2004 at 3:14 PM / IP Logged
i think if your idea is to put switch on your amp, better to use the 12+ instead of your power ant, and besides if you will use that POwer ant it will swithed off when you use your tape deck or cd function...just want know what is the purpose of having switch...since you have the remote function, if not then you need to use manual switch.....
King_Midas
Member - Posts: 35
Posted: July 12, 2004 at 3:30 PM / IP Logged
thanks for the advice. I think I'll check my connections again and if nothing's wrong then I'll go with ketel22 and jgarcellano's ideas. the only problem is that I'm using 8 gauge wire to power the amps but I'm using microswitches. would it be fine to splice a smaller gauge wire like 12 onto the 8 and run that to the switches?
jgarcellano
Member - Posts: 7
Posted: July 12, 2004 at 3:45 PM / IP Logged
to use bigger cable is better but it will cost you a lot ........to modify a terminal lug (TO CUT)just to fit with the cable will reduce the handling capacity (A)...you can use cable capacity (Ampere)table so that you can use the right cable , safe and cheaper....
Charles_R_H
Copper - Posts: 122
Posted: July 12, 2004 at 4:40 PM / IP Logged
what is the whole point of the toggle swiches???
does your deck have both an amp turn on remote and a power antenna remote?
King_Midas
Member - Posts: 35
Posted: July 12, 2004 at 5:09 PM / IP Logged
nope, just a power antenna remote
jugga-nemo
Copper - Posts: 81
Posted: July 12, 2004 at 5:14 PM / IP Logged
I noticed with my Kenwood deck when I fried the remote wire (oops!) that the power ant wire only sent a signal for a brief second when the deck turned on and off, not the radio, but this might not be true of all decks. I would understand the use of toggle switches so that he would be able to turn on and off certain amps/subs while others still play.
5.25" Components & 5x7 Coax Kappas w/Power Acoustik OV4-800
KAC 7252 powering 2 D3 8" Diamonds
KDC-MP728, KGC-4042A
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
