Amplifier Help
dlasanders
Posted: July 25, 2004 at 4:51 PM / IP Logged
I am new to car audio and I have a Sony head unit with a pair of sony 6" 3 way speakers and a pair of 4x6 Sony 2 way speakers which are run off of the head unit amplifier. I don't want to kill any one, I just want a little better bottom so I bought one Sony 10" subwoofer with a max power of 600 watts. My head unit has subwoofer pre amp outs, the only thing I don't know about is what type of amp I need. I would like to stay with Sony but I need to know what type of amp I need, 2 channel? Mono? what??? max power?? I plan to keep the door speakers on the head unit amp and only run the sub woofer off of the amp. Any help will be greatly appreciated.
DYohn
Moderator - Posts: 10,741
Posted: July 25, 2004 at 5:06 PM / IP Logged
Ignore "max" power rating.  Look for the RMS power rating.  Get a mono amp wiht the same RMS power rating as your sub.  Be sure to activate the low pass filter.
dlasanders
Posted: July 25, 2004 at 5:09 PM / IP Logged
Great, thank you very much
dlasanders
Posted: July 26, 2004 at 6:21 AM / IP Logged
I now know I need to match the RMS power but I'm not sure about one thing. My subwoofer has a RMS power of 150 watt and 4 ohm impedance. Do I need to match the 4 ohms also? I see amps advretised as 250 watts RMS at 2 ohms 150 watts RMS at 4 ohms on the same amp. Is this what I need or should my RMS not exceed 150 watts no matter what??? please help!! I am so confused.
defective
Silver - Posts: 642
Posted: July 26, 2004 at 6:41 AM / IP Logged
that amp would be perfect, you need an amp that will do 150RMS at 4 ohms, you could also bridge down to 2 ohm, but matching the impedence will always give you more quality, if the amp has more options, it irrelevent
shaman
Copper - Posts: 70
Posted: July 26, 2004 at 3:05 PM / IP Logged
You need a two channel amp that will make 150 Watts RMS briged on 4 ohms, or a mono amp the makes 150 watts at 4 Ohms.  If you got an amp that made 150 watts RMS at 2 Ohms, and hooked it up to your speaker it would only produce around 75 Watts, so make sure the amp you want to buy will make 150 Watts RMS on a 4 Ohm load.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
