Kenwood DDX7015 problem
fnivme2
Posted: August 02, 2004 at 12:18 PM / IP Logged
While doing some  work on my 2004 F250 Superduty PSD I had to disconnect the batteries.  After reconnecting the batteries I found that the receiver would not turn on.  None of the wiring for the stereo was touched, the fuses ohm out good and there is 12V coming out of both connectors in the rear of the unit.
Any ideas on what would have caused it to die?
louie
Member - Posts: 6
Posted: August 06, 2004 at 12:14 AM / IP Logged
some deck have a reset but you should try that or check to see if you have good ground.
Mac21
fnivme2
Posted: August 06, 2004 at 10:43 AM / IP Logged
Thanks.  I forgot to mention that I had tried the reset.
Figure I will leave it at the service center for the week I will be out of town.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
