two mono amps, each running svc 4Ohm subs
blinginstang03
Posted: August 16, 2004 at 9:05 PM / IP Logged
HI, i am in a dilemma here.
I have 2 1000 watt mono Kenwood amps. I need to run each amp to a svc sub. How do i go about doing that, while running them each at 2ohm?
furflier
Copper - Posts: 236
Posted: August 16, 2004 at 9:12 PM / IP Logged
You can't if the subs are 4ohm's each. You can run both subs parallel to 1 amp for a 2ohm load. In order to do what you are asking you need either 4 4ohm svc subs or 2 4ohm dvc subs.
switch_hitter
Copper - Posts: 151
Posted: August 16, 2004 at 9:45 PM / IP Logged
in order to get 2 ohms per amp you need to get 2, 4 ohm dual voice coil subs, and wire them both in parallel to each amp.
lspker
Silver - Posts: 503
Posted: August 16, 2004 at 9:49 PM / IP Logged
Why run two amps???.   The Kenwood is stable to 1 ohm, where it makes about 485 watts rms (KAC-8101d), at 2 ohms it makes about 400 rms, just parallel the two subs on to one amp, it will make more power and a lot easier to hook up.  If the boxes are on different cars, then you need more sub or dvc.  Or hook the amps in each an move the box around as needed.
switch_hitter
Copper - Posts: 151
Posted: August 16, 2004 at 9:50 PM / IP Logged
or, add more speakers  heh
2 Memphis HPO 12s
1 Memphis 1000D
2 Memphis 8s
1 Memphis MC200
4 Memphis 3way 6 1/2s
1 Memphis MC3004
4 Memphis Tweeters
1 Memphis 3-way electronic crossover
2 Memphis 5 1/4
2 Memphis 4s
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
