97 Cavalier dash lights
xdsltrev
Posted: August 18, 2004 at 8:53 AM / IP Logged
I installed a stereo in my 97 cavalier and now my dash lights and door chimes will not work. I may have accidentally shorted the illumination or dimmer wire.
I tested all the fuses in the fuse panel on the driver side door but they were all fine. Is there another fuse in a different location? If a fuse is not the problem, then what could it be?
Thanks,
defective
Silver - Posts: 642
Posted: August 18, 2004 at 10:22 AM / IP Logged
it will be a fuse under the hood usually 15 amp..... labeled INT or DOME or CTSY......   it's a mini ATC fuse
Alpine Guy
Platinum - Posts: 2,478
Posted: August 18, 2004 at 10:35 AM / IP Logged
you can speed up your search for the fuse by useing a test light, ,or a digital multi meter and check both sides of each fuse for continuity, , , , some times fuses will look ok, but don't let current pass.
defective
Silver - Posts: 642
Posted: August 18, 2004 at 10:42 AM / IP Logged
hey!!!!!!
never recommend a test light Alp.!!
kgerry
Platinum - Posts: 3,455
Posted: August 18, 2004 at 1:06 PM / IP Logged
check to make sure that the grey illumination wire isnt slightly bare behind the radio and shorting or that you didnt mistakenly use it as a speaker wire ( which i've seen done often )
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
