enclosure for four Ma Audio 15s
1 4u2nvy
Member - Posts: 10
Posted: August 30, 2004 at 8:35 PM / IP Logged
ok this is what i have...
 I have a 1995 Cutlass Supreme and i have four Ma Audio 15s and i want to put them in a diamond shaped box and but the subs on the four seperate sides of the box and have a single diamond port in the middle and i jusr wanted help on how to dimensions the box and figure port size and stuff. any help///
jeffchilcott
Platinum - Posts: 2,483
Posted: August 30, 2004 at 9:20 PM / IP Logged
Try going to the Ma audio website.   We would need exact model's of your subs to try to draw up a box.   you could do four square ports at the center of the box for each chamber I wouldnt reccomend it but it would look good if pulled off right
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
auex
Platinum - Posts: 5,041
Posted: August 30, 2004 at 9:26 PM / IP Logged
How many bodies can you fit in the trunk? If less then three you probably don't have the room, especially for ported boxes for 15s.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
1 4u2nvy
Member - Posts: 10
Posted: September 01, 2004 at 5:34 PM / IP Logged
ok to answer both questions first of all to the last one i am going to put them in a wall in the backseat of my car and just have probably an amp rack in the trunk. and they are model 1550W series Ma Audio 15s. i just really need some help on this because i am not sure of what to do.
jeffchilcott
Posted: September 01, 2004 at 5:37 PM / IP Logged
well if your planning on a wall i hope you have alot of time patience and big pockets.   I will see what I can come up with for each box on them, what kind of amps will you be running them with?   where are you from also?
2007 World Record
1 4u2nvy
Member - Posts: 10
Posted: September 01, 2004 at 7:47 PM / IP Logged
i am from around the springfield il area. i am planning on using an mtx amp that i have it is the 81000D amp. and i wanted to know how to get the moost power out of it and what yopu suggested on how to run  the wires. should i run them together or what?
jeffchilcott
Posted: September 01, 2004 at 8:42 PM / IP Logged
well from what I am reading the optimum for each sub would be 3.25 cu ft per sub, the vent would be 37 sq. in by 12.5 long..   as far as power goes you would be underpowering a little bit but you could wire 2 subs in parrallel to get an 8 ohm load then wire those sets of 2 in series to get a 4 ohm load, then bridge on the amp for full power.     But i cant remember if you can bridge the 81000d.    it might just have one output
2007 World Record
Ravendarat
Platinum - Posts: 2,806
Posted: September 01, 2004 at 9:05 PM / IP Logged
are those subs dvc or single, if they are single then I agree with Jeff, If the are dual then I would series each sub woofer and then parallel the sum of them together. The MTX amp has two sets of termianals but is a mono block and bridged internally. So you can just hook up two subs to each set of terminals. BTW, walls arent all that expensive, just generally ugly, thats what I use right now in my S-10. Kinda fun to play with but SQ is absolute sh*t.
jeffchilcott
Posted: September 01, 2004 at 9:14 PM / IP Logged
the subs are only availible in SVC
2007 World Record
Ravendarat
Posted: September 01, 2004 at 9:16 PM / IP Logged
fair enough, if thats the case then that amp is a bad match for those subs. I would either get a second one or sell it off and get something that is either 1 ohm stable or get a couple of mono block amps that are 2 ohm stable.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
