Small 4ch Amp
jdeluna
Member - Posts: 31
Posted: September 07, 2004 at 12:22 PM / IP Logged
I was thinking of replacing my Dodge stock infinity amp, measured it and it is about 7 inches x 6 inches, is there any aftermarket 4 channel amps that are close to this size, even 1-2 inches larger ??? I want to keep the amp pretty much in the same place if possible. Thanks for any info.
raydawg357
Silver - Posts: 769
Posted: September 07, 2004 at 12:51 PM / IP Logged
There are, but are they good quality amps?  I wouldn't trade quality for size.  Get a good 4 channel amp and if it has to be mounted else where, then so be it.   You do know that you will have to replace the speakers also.
Do it right the first time
forbidden
Platinum - Posts: 5,354
Posted: September 07, 2004 at 1:22 PM / IP Logged
Concept HP65.4  is close to the size you need. I use this amp myself.
