Subwoofer connection to standard stereo
al_nunn
Posted: September 24, 2002 at 7:05 AM / IP Logged
Is it possible to connect a vibe active subwoofer to a cars standard headunit? The car is a Toyota Corolla 2002.  The headunit is a "unique fit" so i would like to know if it is possible to connect up an active subwoofer to it?
TheRapture
Copper - Posts: 208
Posted: September 24, 2002 at 10:21 AM / IP Logged
only if the sub is VERY VERY low power... like 50 watts rms...  and thats highly doubtful
what is the wattage of the sub?
Platinum - Posts: 12,488
Posted: September 24, 2002 at 9:11 PM / IP Logged
If you want a 50 watt RMS subwoofer here is one for you:
Boston Acoustics Subwoofer 50 watts RMS
http://www.bostonacoustics.com/ProductSpecs.asp?Productid=93
To add, you can not use your HU power to power this because it's only a full range power ( no crossover ) so you will be feeding the power at full range instead of low pass.
TheRapture
Copper - Posts: 208
Posted: September 25, 2002 at 2:46 PM / IP Logged
in all the years i've been installing stereo systems... i swear to god i've never seen a 50Watt sub!!!!!!
and it's a 12"!!!!!! haaaaahahahaa
ih8u37
Copper - Posts: 54
Posted: September 25, 2002 at 3:15 PM / IP Logged
Go to K-Mart. I'm sure Jenson or Rampage make a 50 watt (max) sub...j/k
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
