My car is not liking any head unit
poeticdrums
Copper - Posts: 49
Posted: October 01, 2004 at 7:17 PM / IP Logged
Hello everyone. I am new to the 12 volt install bay, but I am not new to car audio and the like. Today I got a new clarion head unit so I decided to take out my old sony xplod head unit and put that one in. I took it out, then cut the wires and matched them up with the ones on the new head unit and then when i go to power it on, it does not. The only thing that happens is as soon as I plug in the wires on the HU harness, my power antenna goes up and it starts signaling my amplifier for my subs to start drawing power. So I'm like WTF so I took that one out and pu my old one in and it doesn't work either. The same thing happens. What is going on?
poeticdrums
Copper - Posts: 49
Posted: October 01, 2004 at 7:30 PM / IP Logged
Oh and i forgot to mention that I have checked every fuse in my car, and I tried disconnecting the battery and reconnectin it with no luck
forbidden
Platinum - Posts: 5,353
Posted: October 01, 2004 at 7:34 PM / IP Logged
This has all the indications of a bad ground. Run a new ground wire from the new cd player to a new ground location.
Rushman
Silver - Posts: 380
Posted: October 01, 2004 at 7:43 PM / IP Logged
did you hook up the old sony wiring to the new clarion exactly wire for wire? if so , they probly have a different wiring sequence and you might want to double check it.
poeticdrums
Copper - Posts: 49
Posted: October 01, 2004 at 8:22 PM / IP Logged
I hooked the old sony one up to the same wires that it was connected to before I took it out and put in the clarion. I have a wiring schematic for the clarion and from what I read so far it is the same. Thanks for the input...anyone else?
forbidden
Posted: October 01, 2004 at 8:37 PM / IP Logged
Is the antenna plugged in yet? If it is unplug it and see what happens.
sone4200
Copper - Posts: 34
Posted: October 01, 2004 at 9:06 PM / IP Logged
ihad the same type of problem.... make sure your not using the switching 12+v as power, i did that and felt dumb as hell when i turned my headlights on lol
S-One
1992 Buick Lesabre
Clarion Dxz945MP
2000w Wolfenhag 4 channel amp
2 12" Kicker Solo L7's
poeticdrums
Copper - Posts: 49
Posted: October 01, 2004 at 9:36 PM / IP Logged
The antenna is plugged in...and I know in my nissan tht is supposed to complete the circuit and let it power up but no luck. As for using the switching 12 volt as power, i'm not sure. I think I plugged that into the wire that signals the head unit to start getting power  when the key is turned, although I might be mistaken. I f I can't figure it out tomorrow I know I have like 50 bucks lying around somewhere and I 'll just take it to circuit city and be an idiot for a  day
Alpine Guy
Platinum - Posts: 2,478
Posted: October 01, 2004 at 10:49 PM / IP Logged
Just save your money and do what forbidden suggested.  Run a new ground wire. He dosn't have over 2200 posts for nothing.   I have seen that problem to.  It is the fact that you need a better ground wire.  Just do it.
poeticdrums
Copper - Posts: 49
Posted: October 02, 2004 at 6:02 PM / IP Logged
Okay it's all good now. The deck was just put in today and no more freak outs.
Tuesday, July 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
