Caps and cooling
313Speed
Posted: October 04, 2004 at 1:09 AM / IP Logged
1st... Cap life time.  How long is a cap good for?  And how many would a 2400 peak system need?  The car is new and I cannot add a better alternator because of warrenty concerns.
2nd... Cooling- I have two Phoenix Gold XS2500 amps.  They are cutting because of heat in my Cobra's tiny trunk.  Any ideas on a set up?  How many fans would keep the temps down?
Thanks!
jeffchilcott
Platinum - Posts: 2,483
Posted: October 04, 2004 at 4:37 PM / IP Logged
I would use 2 fans per amp, one for pulling air in one for pushing air out.... I try to keep my in draft of air close to the coils so they are cooled very well.   also make sure to use some type of screen under the fan so you dont get crap in your amp.   I really havent seen 2 many caps die they normally last pretty long.    2400 watts dosent tell how many caps you need,    tell me the amperage draw of the amp ( fuse size is a good tell) and the size of your alternator
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
