Check out newbie's $800 system
Ringo
Member - Posts: 13
Posted: October 09, 2004 at 4:56 PM / IP Logged
Alpine CDA9820XM head unit
Sony Xplod XSW1621 6.5" in front
Pioneer TS-A6870R 6"X8" in rear
Alpine MRP F240 360 watt 4 channel amp for front four speakers
Kenwood KFC-W3009 12" sub in single BLACK/ chrome bandpass box
Kenwood KAC5201 250 watt amp to drive the sub
(2) 8 gauge kits to wire amps
Alarm with remote start, keyless entry and LCD pager remote
I spent about $800 on everything.  All parts are brand new.
All wiring either soldered or tightly crimped, and covered with heat shrink.
I have to finish installation this week, so far the head unit and front speakers are in.
It is going into a 1990 full sized Ford Bronco.  I am also going to Dynamat the front four speakers.
I will let you know how it sounds when done!
1990 Ford Bronco XLT Alpine/Kenwood XM system 2 amps 5 speakers Keyless entry remote start soon to have DVD player
2001 Harley FXSTS
Alpine Guy
Platinum - Posts: 2,478
Posted: October 09, 2004 at 5:01 PM / IP Logged
thats a lot of stuff for $800!!  I hope you enjoy it!
Ringo
Member - Posts: 13
Posted: October 09, 2004 at 5:05 PM / IP Logged
Thanks.  And sorry about your friend.
Yeah, I shopped carefully.  none of the stuff is "warm" in any way!
Ebay is very helpful, if you are careful.
And I got the Kenwood amp for free when I bought the head unit at Car Toys.
Putting it all in is a PITA but it is worth it in the end.
2001 Harley FXSTS
Alpine Guy
Posted: October 09, 2004 at 6:40 PM / IP Logged
Good ol e-bay .   And thanks for being the first guy to notice and show concern for my friend.
Rushman
Silver - Posts: 380
Posted: October 09, 2004 at 10:31 PM / IP Logged
Way to go Ringo ! ! ! Bravo for taking your time to do it right. You will be so much better off in the long run. Ive ALWAYS said installation is Half the game. Good luck.
jeffchilcott
Platinum - Posts: 2,483
Posted: October 10, 2004 at 1:17 PM / IP Logged
just a question why are you running 2 8 guage kits instead of 1 4 guare kit?
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Ringo
Member - Posts: 13
Posted: October 10, 2004 at 6:50 PM / IP Logged
No reason, I just wanted to make sure to have enough wire and fuse holders.  I got a good deal on them so I bought two.
Also, my needs do not require a 4 gauge kit, so I figured why hassle with the thick wire if it is not necessary.  In fact I don't even need 8 gauge, but I would rather be a little over than under.
2001 Harley FXSTS
stevdart
Platinum - Posts: 5,816
Posted: October 10, 2004 at 7:35 PM / IP Logged
Huh??  All I gotta say is...it's a good thing you didn't find a good deal on 10 gauge!  8 ga. is bare minimum for your system as long as your running all speakers and sub at 4 ohm impedance.
The other thing is this:  you bought a bandpass box with the sub.  You should think about swtching to a sealed enclosure instead.  Or maybe simple ported.  You've only got 120 watts going to the sub with that amp.  Your enclosure is designed for SPL, but you've got a minimal setup.  You will need to get more frequency range out of your sub than a bandpass will allow.
