no power to head unit
supradude
Silver - Posts: 915
Posted: October 20, 2004 at 7:47 PM / IP Logged
 a weird thing happened yesterday. when i cranked my car, the head unit never came on. as i was driving along, i turned it off and on several times, but it never lit up (came on) . then later that evening i cranked the car again and it came on and played just like it allways has. and it has been coming on every time since. i thought a fuse had blown the time when it did not come on, but it is working fine now. i've never seen anything like this in my 45 years. has anyone got any ideas?
'85 Toy
stevdart
Platinum - Posts: 5,816
Posted: October 20, 2004 at 10:42 PM / IP Logged
Probably ignition switch is getting dirty contacts.  Sometimes they quit working altogether because of dirty or worn contacts, and sometimes you see something not working momentarily, like what you experienced.  Normally, though, turning it off and on several times will eventually make contact.  But it didn't in your case.  Anyway, that is what I would suspect, as that is where the electrical contacts are made.
djv1
Member - Posts: 42
Posted: October 20, 2004 at 11:58 PM / IP Logged
Maybe one of your wire connections is loose, going into the fuse box or on the wire harness for the deck.
JVC deck
6.5in MB Quarts
Rockford 3001M amp
2 12in Kicker Comps
Sirus Sattilte Radio
supradude
Silver - Posts: 915
Posted: October 21, 2004 at 5:32 AM / IP Logged
that makes sense. is there any way to spray something into the ignition switch without taking it apart to clean it? i have been having to turn the key pretty hard first thing in the morning lately to get it to move.
'85 Toy
jeffchilcott
Platinum - Posts: 2,483
Posted: October 21, 2004 at 7:56 PM / IP Logged
i would think a mulit purpose lube would work just dont put any KY in there
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
markcars
Silver - Posts: 662
Posted: October 22, 2004 at 11:11 AM / IP Logged
Could it be possible that one of your power wires coming into the head unit was loose? If thats the case, this might happen again later. You might want to make sure the power is coming into the HU before more major steps. Just another idea.
DukeDuke
Silver - Posts: 206
Posted: October 22, 2004 at 11:36 AM / IP Logged
You can put graphite in there, that is why I put in my key holes to get my keys to go in earier and turn better.
Duke Duke
pimpincavy
Silver - Posts: 880
Posted: October 22, 2004 at 12:09 PM / IP Logged
That happned to me two or three time in my other car.  One time i took all the fuses out and put them back in, then it came on.  The other time I unplugged the HU, plugged it back in, then it came on. However,  ts very possible that boththose things were coincedences, and had nothing to do with teh HU coming back on.
supradude
Silver - Posts: 915
Posted: October 22, 2004 at 7:44 PM / IP Logged
thanks for all the advice. i have been looking, so far i still don't know what happened. i didn't see anything loose though.
'85 Toy
