alpine era-g20 digital eq
pbmswt69
Member - Posts: 8
Posted: October 29, 2004 at 3:07 PM / IP Logged
Does anyone know where I would connect the 12v power and ground if I'm mounting the brain in the trunk? The harness wires are only 12 inches long if that.  thanks
Rushman
Silver - Posts: 380
Posted: October 29, 2004 at 7:31 PM / IP Logged
The ground wire can be grounded there in the trunk. I dont know what kind of car you have but Im sure there is a bolt or screw of some kind you could use there. Be sure to grind off the paint where it makes contact. As far as the 12v power wire , you probly need to run a single wire for that to the front of the car to a 12v sorce. Maybe the cig. lighter , fuse block , the head unit.....ect.ect. Is there a remote turn on for that unit ? If so you will need to run a wire for that as well.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
