8 ohm speaker need, need 4 ohms
mgj79
Posted: October 29, 2004 at 8:59 PM / IP Logged
I have an 8 ohm 150 watt 8" sub.  I need to get it down to 4 ohms, so I can drive it with my amp.  I know I can parallel it with an 8 ohm resistor, but my question is what wattage should the 8 ohm resistor be?  I really appreciate any info you guys can give me.  Thanks
stevdart
Platinum - Posts: 5,816
Posted: October 29, 2004 at 9:14 PM / IP Logged
You don't need to get it down to 4 ohms, because 8 ohms puts less strain on the amp.  It's an easy load for an amp to handle.  You'll get the same result in output as using a resistor and keep it easier on the amp, too.  Keep in mind, what the resistor would do is take half the power and convert it to heat.  Not necessary.
