pioneer head unit question
Detour
Member - Posts: 20
Posted: November 03, 2004 at 4:00 PM / IP Logged
I'm surrently wiring lights onto my car but I would like to use the stereo as a cut off switch.  Which wire do I tap into on the headunit to only get power when the face is on?
jeffchilcott
Platinum - Posts: 2,483
Posted: November 03, 2004 at 4:40 PM / IP Logged
your remote wire, but that wont supply enough current to run any lights.    You will have to run a relay with a 12 volt source
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Detour
Member - Posts: 20
Posted: November 03, 2004 at 4:48 PM / IP Logged
What I was thinking of doing too was running the power wire from the fuse box to the toggle switch then to the head unit then to the lights.    [fuse box] --> [toggle] --> [h.u] --> [lights]  Dont know if that would change anything.  And the lights are federal signal police issue wigwags if that matters.
DYohn
Platinum - Posts: 10,741
Posted: November 03, 2004 at 4:55 PM / IP Logged
No, that's not a good idea.  Chances are the lights will induce lots of noise into the power wire and thus into your HU.  Plus, it is never a good idea to use a toggle switch for a load like lights that can draw significant current.  Like Jeff suggested, your best bet is to use a relay and trigger it off the remote-on signal from the HU.
Detour
Member - Posts: 20
Posted: November 03, 2004 at 8:02 PM / IP Logged
Even though they only use 10 amp loads?
dpaton
Copper - Posts: 141
Posted: November 03, 2004 at 10:30 PM / IP Logged
10A is a lot of current. Most switches are only rated for 1 ro 2 or 3, mayve 5A on a good day. Anything over 1A really wants a relay to prevent arcing and to keep the current in the fat wires and contacts, not in the wimpy ones inside a switch.
-dave
This is not a sig. This is a duck. Quack.
