mb quart setup
ksingh
Copper - Posts: 62
Posted: November 24, 2004 at 7:53 PM / IP Logged
hey whats up fellas i recently installed some 6.5 component setup in my 1996 honda accord and also some 6.5 add on woofers
however when i finished installing everything it worked great then i took everything out meaning the amps and the caps to make a nice amp rack for it also wtih the crossover now when i hooked everything up again i ran into a problem , as soon as i put the volume up to 26 it just cut off then i have to turn off the radio and put it on again then the amp is in protection mode and i checked all the wires and cant figure it out
i mostly do alarms and stuff but have experience in the caraudio dept but not that much
can anyone help me out please
Kenny
kfr01
Gold - Posts: 2,121
Posted: November 24, 2004 at 8:23 PM / IP Logged
Sounds like you fried your amp.
You'll want to tell us about how you have the power and ground wired for the amps and caps.
New Project: 2003 Pathfinder
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
