Volume calculater?
astro88
Copper - Posts: 195
Posted: December 02, 2004 at 5:39 PM / IP Logged
Was just reading through klappings post were and found that my calculations were wrong?
I did what it says to do, does this calculater not work right?
Just checked what would come out for 14"high,27" wide,12" deep and got less than 1 cube each?
auex
Platinum - Posts: 5,041
Posted: December 02, 2004 at 5:49 PM / IP Logged
If you don't think the calculator is right then open the regular calculator on your computer. Then take the internal dimensions of your enclosure. Then do this "LxHxW=X" then take "X/1728". Now you have the volume of your box.
Please don't start this crap again. I don't understand why this is so complex to understand.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
astro88
Copper - Posts: 195
Posted: December 02, 2004 at 6:03 PM / IP Logged
Please don't start this crap again. I don't understand why this is so complex to understand.[/QUOTE]
WTF! I'm not starting any"crap" Ive used this calculater to make boxes and now i find ou its WRONG?
I will use the other "math" from now on but the boxes ive made are now found to be "off"
What bout the series calc? and all the others?
auex
Posted: December 02, 2004 at 6:12 PM / IP Logged
I didn't specifically say that towards you, just this post in general.
Honestly, I don't use any of the calculators on the site, I just do the math. From what I have used, the resistance calcs are correct.
DYohn
Platinum - Posts: 10,741
Posted: December 02, 2004 at 6:21 PM / IP Logged
The calculators on this site assume that all the dimensions you enter are reduced by 2X the thickness you list.  So as long as you are building your enclosure with all mitre joints it works just fine.
kfr01
Gold - Posts: 2,121
Posted: December 02, 2004 at 6:23 PM / IP Logged
The math you some of you were using in that long thread was just wrong.  You only took 3/4 inch off each dimension.  You should have taken off 1.5"
The calculator is right.  We should close this topic.
Edit:  always beat to the punch by DYohn.  Volume calculater? -- posted image.
New Project: 2003 Pathfinder
astro88
Copper - Posts: 195
Posted: December 02, 2004 at 7:26 PM / IP Logged
So if i wanna measure 30x12x12 w/ .75 mdf i would put in 1.50 for the thickness?
Thats not how the explanation above the calculater says to do it?
kfr01
Gold - Posts: 2,121
Posted: December 02, 2004 at 7:41 PM / IP Logged
No, you'd put in .75. The calculator is 100% right. The math on that old thread was wrong.
astro88
Copper - Posts: 195
Posted: December 02, 2004 at 7:47 PM / IP Logged
So if i build a 12x12x12  box w/.75 wood the vol would be 0.66992?is that accurate?\
Please help, very confused!
auex
Posted: December 02, 2004 at 9:02 PM / IP Logged
Alright, internally the dimensions are (10.5x10.5x10.5). So when you multiply that you get 1157.625 cubic inches, after you convert that to cubic feet you get 0.66992. So this checks out.
Sometimes it is hard to picture it in your mind 3 dimensionally.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
