No Power to head unit, 97 Tbird
Franky-5-Fingaz
Posted: December 06, 2004 at 5:49 PM / IP Logged
Hey my first post, well im having a problem with my new jensen head unit. I removed the factory amp and installed my own pioneer 4-channel amp. When i plugged all the wires in and was just about finished with my install the head unit woudldnt turn on, i saw it was a fuse on the red 12V power wire, i replaced it with a similar 250 VL fuse, and it still wont work. Any suggestions? Should i just take it to a shop?
Frank Williams
1997 Ford T-bird
1997 VW Jetta Trek 2.0
few bolt-ons, pioneer amp, jensen head unit... just the begining
jstruckman
Copper - Posts: 465
Posted: December 06, 2004 at 6:35 PM / IP Logged
check the fuse panel in the vehicle, you may have blown a fuse there.
Jazzy
furflier
Copper - Posts: 236
Posted: December 06, 2004 at 6:36 PM / IP Logged
Check all your fuses @ the fusebox. You probably blew one there also. But before replaceing your fuses you need to go over all your wiring. Make sure every wire is connected right & make sure all the splices are taped. A fuse doesn't blow for no reason.
