JL Subs. 2x W6s or a w7?
bizzeh
Posted: December 08, 2004 at 2:37 PM / IP Logged
As the title says, i can't make my mind up as to which will sound better.  I`m planning on porting and dropping pretty low when needs be, and will also be running a PG Bass CUBE from an undetermined head unit and powering the sub(s) from JL 1000/1 amp.
any advice is muchly welcomed..
Biz
Teamrf
Gold - Posts: 1,031
Posted: December 08, 2004 at 3:08 PM / IP Logged
One of either sub sounds good....but I would go with the two w6's.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
wheelerdr
Copper - Posts: 337
Posted: December 10, 2004 at 3:43 AM / IP Logged
what are you putting this setup in
bizzeh
Posted: December 15, 2004 at 5:54 AM / IP Logged
its going in an Audi A4 (B5) saloon..... i`m still unsure as to go with either the one big sub or the combination of the 2.....
Alpine Guy
Platinum - Posts: 2,478
Posted: December 15, 2004 at 2:59 PM / IP Logged
1, 13W7 would be my choice.
kfr01
Gold - Posts: 2,121
Posted: December 15, 2004 at 4:09 PM / IP Logged
If you want to see how the estimated difference will look, download WinISD pro and model it out. My guess is that there will be little SPL difference between the single w7 and the 2 w6 drivers. I'd probably pick the single w7.
New Project: 2003 Pathfinder
