Subwoofer help
Neves2000
Posted: December 09, 2004 at 2:40 PM / IP Logged
I have a 2 channel, 1200 watt punch amplifier and i'm trying to hook up 3 kicker 15'" subwoofers. Anyone know how I would connect the subwoofers? I know there are a number of possibilities but I just wanted tome imput on the easiest way.
Teamrf
Gold - Posts: 1,031
Posted: December 09, 2004 at 2:43 PM / IP Logged
What kind of Kicker subs....Dual Voice Coil? And if so what are the impedance of the subs..
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Neves2000
Posted: December 09, 2004 at 2:47 PM / IP Logged
kicker comp. Not sure about impedance...but they can hold up to 1000 watts  each if that helps any. I have 2 connected but i wanted to add a 3rd one.
Neves2000
Posted: December 09, 2004 at 2:49 PM / IP Logged
i'm not a technician so i don't know all the terminology sorry
forbidden
Platinum - Posts: 5,354
Posted: December 09, 2004 at 5:28 PM / IP Logged
You need to post the exact model# of the subs (the number and impedence of the voice coils) and the exact model# of the amp please.
wheelerdr
Copper - Posts: 337
Posted: December 10, 2004 at 2:59 AM / IP Logged
can you post the ohm rating on the amp as well this will help
crispycritter91
Member - Posts: 15
Posted: December 10, 2004 at 5:26 AM / IP Logged
You can get the # of voice coils and resistance IE Ohm  from the paper work with your sub or by looking at the back of the subwoofer. Another way to tell if it is single or dual voice coil is the terminals on the back of the sub. If you see 1 terminal ( + and - or Red and Black) you have a single Voice coil. If you see two terminals then you have a dual voice coil ( 2 + and - or 2 Red and Black Terminals). For the amp you can look into your paperwork that came with your amp and see if it says " # Ohm stable in mono or 1 channel operation". If you dropped big bucks into your amp it might be 1 Ohm stable in 1 channel. But in most cases its only 4 Ohms in 1 channel or 2Ohms in stereo or 2 channel mode.. (4ohms left channel and 4ohms right channel combined)
