noise from equalizer
bassrider20hz
Member - Posts: 40
Posted: December 16, 2004 at 1:21 AM / IP Logged
hello to the 12volt community
I have engine noise in my system its really loud. its coming from my DHD preamp equalizer. its not my HU or amp. the EQ is sharing the same ground as the HU and the same ACC power. could this be the problem if so where else in the car can i find another ACC wire to power the seperatly.
Thank you all in advance to all who post and help me.
sbcaprice305
Copper - Posts: 57
Posted: December 16, 2004 at 2:50 AM / IP Logged
often the problem lies in the ground...
find a peice of metal around the mounting area...drill a hole, scrape all the paint off untill bare metal..then ground it to that...
fuseblower
Silver - Posts: 403
Posted: December 16, 2004 at 11:06 AM / IP Logged
If your ground is good it could be that the eq is bad.  Time to replace it.
