ohm's law question
djdaveoc
Copper - Posts: 231
Posted: December 20, 2004 at 6:56 PM / IP Logged
I have a sub with 2 4-ohm voice coils.  If I want to run a sub amp in mono, how many ohms load with the sub be?  I'm asking because I'm trying to pair up a sub with an amp that will be a good fit power wise.  Thanks for any help.  I'm a brand newbie to car audio!
ohm's law question -- posted image. Plan, Research, Do
Lizardking
Copper - Posts: 184
Posted: December 20, 2004 at 7:33 PM / IP Logged
Wired in parallel that would be a 2ohm load to your amp...If you run in series I believe that would be a 8ohm load to your amp..
Eclipse "Approaching Perfection"
darthness
Copper - Posts: 136
Posted: December 20, 2004 at 7:37 PM / IP Logged
and in case you didnt know, you'll want run a 2ohm load, not 8ohm.
contrary to most things, smaller amount of ohms = better. i forgot why though :))
12v.boogie
Member - Posts: 11
Posted: December 20, 2004 at 7:40 PM / IP Logged
wired in parrell its 2 ohm but if you monoout an amp it cuts it down to a 1 ohm.
Lizardking
Copper - Posts: 184
Posted: December 20, 2004 at 7:43 PM / IP Logged
Lower the ohm the better unless you push your amp to it's limits then it's not..
pneise
Posted: December 20, 2004 at 8:21 PM / IP Logged
lower resistance means more current for a given voltage=more power to speaker :)
stevdart
Platinum - Posts: 5,816
Posted: December 20, 2004 at 8:24 PM / IP Logged
Shop for a mono class D amp with ratings that include wattage at a 2 ohm load impedance.
djdaveoc
Copper - Posts: 231
Posted: December 20, 2004 at 8:49 PM / IP Logged
I know I mentioned the dual VC sub but now I'm thinking of getting a JL Audio 12W7 since I already have the subzone box for it.  Any suggestions on the amp brand and model?  I'm thinking maybe a PPI but if there is an amp that would be a good fit for a 12W7 that costs less than PPI but is almost as good, I'm open to ideas.  I just want to make sure and power the sub to it's full RMS capacity which I believe is 750 watts RMS into one 3-ohm voice coil.  Thanks again!
djdaveoc
Copper - Posts: 231
Posted: December 21, 2004 at 6:01 PM / IP Logged
Lizardking what is the difference between wiring in parallel and wiring in series?  Thanks.
stevdart
Posted: December 21, 2004 at 8:30 PM / IP Logged
Incredible what you find out with a Google search!  288,000 results in a quarter second....but you'll find all you need on the first page.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
