Pioneer GM-2200 Amp
danpegg
Posted: April 25, 2002 at 7:45 AM / IP Logged
I have just been given a Pioneer GM-2200 and I am having problems getting it to work. On the amp there is no remote on connetor like on most other amps, the only other option I can think of to turn the amp on is the 3-pin connector. Is this correct?
Does anyone have this amp and know how to turn the amp on without using the correct connector?
Regards,
Dan
pat28ca
Member - Posts: 45
Posted: April 26, 2002 at 8:47 AM / IP Logged
you should do a search on the net for the amp if not search pioneer electronics and they have downloadable product manualss for every thing they have ever built.
zippy
Posted: September 04, 2002 at 6:23 PM / IP Logged
Hi, like u i have been given one of these amplifiers and am having the same problem powering it up. Although i have tried searching the pioneer site but to no avail. If anyone does find away of doing it please let me know!
mike/zippy
zippy
Posted: September 05, 2002 at 5:46 PM / IP Logged
I managed to get the amp powered up. I did draw a diagram to show it was done but i can't add it in ere so i'll explain!!
Basically connect up the battery to the amp as u would normally, but to turn it on you need to use the first two of the three pins on that 3-pin connector (pins 1 & 2 nearest the speaker connectors) and take them to battery + terminal connection on the amp and it turns on.
Hope this comes in usefull
mike/zippy
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
