Alpine SWS1241 box info needed
forbidden
Platinum - Posts: 5,354
Posted: December 22, 2004 at 6:28 PM / IP Logged
I need some box info for a pair of these 12" svc subs. I need to make the boxes individually in order to get them into the customers car. Anyone have box info for these subs, customer would prefer a slot ported enclosure. His vehicle is a 98 Prelude, subs will have to fire backwards and the slot port out the top in order for it to fit. 29" between wheel wells leaves 14.5 " for each sub, 13" in height. If a miracle happens I may be able to fit the slot ports down each side of the box.
customsuburb
Gold - Posts: 1,813
Posted: December 22, 2004 at 7:58 PM / IP Logged
Somewhere on the net I found a spec for a ported box ranged from 1.25 to 2.00 cf. I'm pretty sure I've seen then at a local car audio shop in about a 1.5 cf slot ported box. It sounded pretty good too. Hope this helps you with your problem. Look at this link (scroll down towards the bottom).
jeffchilcott
Platinum - Posts: 2,483
Posted: December 22, 2004 at 9:26 PM / IP Logged
rob, have you tried calling alpine?
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
jeffchilcott
Posted: December 22, 2004 at 9:34 PM / IP Logged
Rob if you send me Your email address I have an Adobe Acrobat file that includes the manual for the SWS-1041, SWS_1041d..the SWS1241 and 1241d
2007 World Record
forbidden
Posted: December 22, 2004 at 9:51 PM / IP Logged
Alpine here is pretty much useless as I am not a authorized dealer. We ended up going with a sealed box and from what I have found so far it should sound just fine for him. Thanks for the help anyhow. I found the same file as you have Jeff, matter of fact one of the other local installers had it saved in his database.
jeffchilcott
Posted: December 23, 2004 at 12:14 AM / IP Logged
glad to hear it worked it out.   If you ever need any sub parameters let me know I have about 2500 diffrent subs of all years, brands, and model's that I have accumulated over the years.    I have them all on the laptop, which is handy cause that is usualluy where I come to the 12 volt from!
2007 World Record
