91 Taurus Head Unit
lillowek
Member - Posts: 27
Posted: December 28, 2004 at 9:50 AM / IP Logged
HELP!!!
First off, it's a 91 Ford Taurus Sedan.
I got my mother a new head unit for her for xmas, however, I'm having some problems. Mind you, I have hooked up several stereos, and this has me somewhat stumped.
I took the stock head unit out. It has 2 plugs, and from looking up the # of the head unit, it's not the premium setup.
I got my harness, and pluged it into both harnesses after hooking up all the proper wires.
Only the front 4 speakers came on, not the back 2 in the rear deck.
However...
If I hook up pos to neg, and neg to pos on the rear speakers, they come on fine.
I noticed that it's only got 5 speaker wires coming out of the stock harness. I'm taking it the front left 2 are hooked together, and the front right 2 are hooked together. Also, it leads me to believe that all the speakers either share one ground, or one positive.
The question roughly is, is it supposed to be hooked up this way to work, or is something wrong? lol
Also, on the back of the back seat there are 2 electronic boxs. Are these amps for the car stereo, or not??
Thanks alot!!!
Jeremy
tech460
Copper - Posts: 118
Posted: December 28, 2004 at 10:23 AM / IP Logged
This vehicle is factory amplified. The amplifier uses 1 common ground for negative and 4 positive leads. You will have to either bypass the amp by running new leads to each speaker or get a harness to keep the amplifier activated. Metra is the only company I know that makes one, 70-1768.
Also, some (very few) of these cars had a jumper to the right of the radio opening to bypass the amp. If it does it will look like the main harness. Simply unplug the jumper and use the harness you have now. Again, this is rare.
lillowek
Member - Posts: 27
Posted: December 28, 2004 at 10:29 AM / IP Logged
Wow,  thanks for the prompt reply.  :)
I actually have the jumper harness,  but where is this amp located???
Thanks!!!
tech460
Copper - Posts: 118
Posted: December 28, 2004 at 10:44 AM / IP Logged
It should be in the trunk, next to the rear quarter panel behind the carpet.
lillowek
Member - Posts: 27
Posted: December 28, 2004 at 10:51 AM / IP Logged
Which side,  drivers side or passenger side?
There are 2 electricle boxes right on the back seat  mounted,  I didn't know if that was those or not
If you can tell me what side,  I would be happy.  Pictures rock to. :)
Thanks!
tech460
Copper - Posts: 118
Posted: December 28, 2004 at 11:31 AM / IP Logged
Sorry, drivers side.
lillowek
Member - Posts: 27
Posted: December 28, 2004 at 11:49 AM / IP Logged
Sweet!!  I'll look into this.
Umm,  any idea what the electronic boxes are on the back seat?  I can get pictures if need.  I'm at work now though.
tech460
Copper - Posts: 118
Posted: December 28, 2004 at 1:51 PM / IP Logged
Assumption, one should be your illuminated entry module for your interior lights, and the other should be your rear brake sensor module.
lillowek
Member - Posts: 27
Posted: December 28, 2004 at 2:13 PM / IP Logged
Thanks meng!
If you have AIM,  can you post it up here for me?  Or , you can AIM me.  My name is the same as this username.  I wont be on AIM until after 4:15 or so though.
tech460
Copper - Posts: 118
Posted: December 28, 2004 at 2:25 PM / IP Logged
Sorry, I don't have AIM. You can PM me if you want.
Page of 5
