Honda Head Unit Aux
Welcome Guest :)
toiday
Member -
Posted: January 02, 2005 at 1:27 AM / IP Logged
I have a 2005 Odysey EX. The head unit has a XM/AUX button. I want to use the AUX input to add sound for a DVD player. Can anyone help me out with the 14-pin connector pin-out?
Thanks!
biker8018
Copper -
Posted: January 02, 2005 at 3:49 AM / IP Logged
| INSTALLATION INSTRUCTIONS FOR THE HON-AUX |
| The HON-AUX will convert the CD changer port of the Honda/Acura radio to an auxiliary input.NOTE: For proper operation of the HON-AUX, the factory CD changer, if present, will need to be disconnected from the factory harness.· Compatible with Pioneer Universal XM Satellite Digital Tuner System (GEX-FM903XM), when used with PIE Part# PIO/P-RCA.· Compatible with Sony Universal XM Satellite Digital Tuner System (DRN-XM01R, DRN-XM01C), when used with PIE Part# 3.5-RCA6MM. |
| CAUTION: Before any connections are made, P.I.E. strongly recommends that all circuits be verified with a voltmeter before interfacing with them. Always set the parking brake before working on any vehicle. |
| DO NOT force connectors together as pin damage may occur. This installation will be flawless if you take your time making the connections described below. Following the installation sequence below is critical to ensure proper recognition of the CD changer by the factory radio. |
| INSTALLATION: |
| 1. Disconnect the negative battery terminal. 2. Remove the Honda radio to gain access to the connectors on back of radio. 3. Determine the plug type and configuration. (See diagram on reverse) NOTE: Vehicles with separate cassette decks will use this adapter at the data port on the back of the cassette deck. NOTE: Vehicles that are pre-wired for a CD changer will need to have the DATA cable removed from the radio in order to install the HON-AUX. 4. Connect appropriate length patch cord (not included) between HON-AUX and auxiliary device. 5. Reinstall the factory radio. 6. Reconnect the negative battery terminal. |
| VERIFY OPERATION: |
| 1. With radio on, activate auxiliary device. 2. Press 'CD' button on radio to gain access to auxiliary audio input. 3. Display on radio will show CD 1 TRACK 1, and the audio of the auxiliary device will be heard. 4. Adjust volume levels of auxiliary device. (If applicable) |
Thursday, April 23, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
