91 ford explorer stereo wiring
rsudbay
Copper - Posts: 68
Posted: January 05, 2005 at 10:36 AM / IP Logged
i am installing a radio in a friends car. it is a 91 ford explorer. he has like 24 wires coming out the radio hole. supposably he has another friend try to install it and failed. but i have done acouple of radio. and i have never seen more than 15 wires back there. but my question is if i have a couple of wires. how do i test wires to find out wich ones are speakers. so how do you test for speaker wires? i have a multimeter and a continuty checker. but i dont know how to test for speakers. please help
hey, everyone has got to start somewhere. but ill learn
DYohn
Moderator - Posts: 10,741
Posted: January 05, 2005 at 10:48 AM / IP Logged
Did you cut off the wiring harness plug?  Ooo, bad move.  Never do that, always purchase an adapter.  Here, this is all I know:  1990-91 Ford Explorer Stereo Information
rsudbay
Copper - Posts: 68
Posted: January 05, 2005 at 10:56 AM / IP Logged
when i got to the car all the harneses where already cut. but my question was how to test wires to find which one is the speakers? because none of the speaker wire colors in that diagram, match the wires in the car.
DYohn
Posted: January 05, 2005 at 11:30 AM / IP Logged
Then the vehicle probably has the "premium sound system" with external amplifiers, so there are no speaker wires at the old HU location.  I recomend you purchase the Ford wiring diagram book for the truck.
In general, speaker wires in OEM wiring harnesses are matched color pairs, with one wire being solid and the other being striped.  Identify the pair (such as purple and PURPLE / white) and test continuity between them.  You should read 2 to 6 ohms.  Then you can "pop" the speaker with a battery to ensure you actually have a speaker pair and to identify which one it is.
rsudbay
Copper - Posts: 68
Posted: January 05, 2005 at 11:50 AM / IP Logged
how do you do that. just hook the positive to the positive side of a AA and negitive to a negitive??????
KarTuneMan
Platinum - Posts: 7,056
Posted: January 05, 2005 at 12:09 PM / IP Logged
Use an old 9V battery.....much easier to hold, and NO it won't hurt your speakers.
