running wires
Xplorer
Copper - Posts: 69
Posted: January 11, 2005 at 2:15 AM / IP Logged
i got a street wires amp kit that has a remote turn on lead attached to the RCA's. Wont that cause some signal noise if i run them together? also what are my options as far as which wire to connect my remote turn on to...amp power wire...HU power wire...switched 12+? If i run RCA's next to existing stock wiring (ie. tail light wiring etc in the side paneling) will it cause signal noise?
Peace
dwarren
Posted: January 11, 2005 at 2:25 AM / IP Logged
If you do not want the remote turn on wire that comes with the rca's, don't use it. just get some 16-18 gauge wire and run it along with your amp power cable. but its probably not going to interfere with the signal any way.
The remote turn must be connected to the designated connection on your deck. i.e. the Remote+. If you connect it to another constant or the power antenna, the amp will remain on at all times or only if the radio is on.
Hopefully the other factory wires will not interfere with the signal path, usually they don't. if they do you may need to re-route your rca's or or increase the the signal voltage
pimpincavy
Silver - Posts: 880
Posted: January 11, 2005 at 11:20 AM / IP Logged
The amp turn on wire shouldnt have enough power moving through it to interfere with the RCAs.
esmith69
Gold - Posts: 1,511
Posted: January 11, 2005 at 6:12 PM / IP Logged
[QUOTE=pimpincavy]The amp turn on wire shouldnt have enough power moving through it to interfere with the RCAs.[/QUOTE
agreed.  The current going through those turn-on wires is usually less than one ampere and I've never had any problems running it next to RCAs.
Ethan
Donate to the12volt.com
Xplorer
Copper - Posts: 69
Posted: January 12, 2005 at 1:06 AM / IP Logged
Alright thanks for the info guys...i look forward to installing all weekend (lol)
Peace
slammedb5
Copper - Posts: 103
Posted: January 12, 2005 at 3:53 AM / IP Logged
Just so you know, the wire attached to the RCA's is NOT intended to act as a remote turn on wire (although it will work with no problems). If you decide to run a seperate remote, I suggest running it with your power wire, although I have never experienced interference from a remote wire run with RCA/speaker wire.
Tuesday, April 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
