Running 4Ga Power wire through Caddy
z28cmr83
Member - Posts: 7
Posted: January 12, 2005 at 2:01 PM / IP Logged
In a 92 deville, how would you get the 4gauge power wire through the fire wall, and all the way through to the trunk, is it any harder/different than running it through a two door?
any tips appriciated. thanks.
hoaxs
Copper - Posts: 95
Posted: January 12, 2005 at 7:30 PM / IP Logged
Check for any gromits in the fire wall.  If there is you can run thought there. If there isn't you can follow your brake boster and follow the pedal and check the inside by your brake pedal and see  if theres  anything in the way.  If there isn't just be carfull and drill a hole and make sure you put some type of gromet in the hole so it doesn't tear your wire.  And last you can run it under the car and put the power wire in Conduit Armor and drill a hole in your trunk and make a water proof seal in the trunk.
Hurry get me a steel hanger, elec tape, zip ties, a monkey and a snorgle. trust me i've ran wires with less
hoaxs
Copper - Posts: 95
Posted: January 12, 2005 at 7:31 PM / IP Logged
Check for any gromits in the fire wall.  If there is you can run thought there. If there isn't you can follow your brake boster and follow the pedal and check the inside by your brake pedal and see  if theres  anything in the way.  If there isn't just be carfull and drill a hole and make sure you put some type of gromet in the hole so it doesn't tear your wire.  And last you can run it under the car and put the power wire in Conduit Armor and drill a hole in your trunk and make a water proof seal in the trunk.  it's is harder to run these ways but looks hell of alot cleaner.
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
