2005 Silverado 12v source
jwitt
Posted: January 13, 2005 at 12:15 PM / IP Logged
I am installing a Soundgate KNGM1V6 translator to connect a Sirius Kenwood tuner to the RDS radio.  My question is what is the best place to get the +12 volts?? I have read here that the Ign or battery wire at the back of the OEM radio is only 6 volts and not a good option. Thanks, JIM
jaurora
Silver - Posts: 429
Posted: January 13, 2005 at 3:26 PM / IP Logged
Constant  +12 Volts:
RED
IGNITION SWITCH HARNESS
This wire will be seen below the steering colomb. It is a heavy guage wire. This is a constant 12vdc so be sure to use a fuse. Also only use this wire if the unit you are hooking up is less then 15 amps. Going to the battery is more prefferd!
MECP certified (If it really means anything)
Jeremy
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
