2004 Silverado Install
rviper488
Posted: January 21, 2005 at 8:16 PM / IP Logged
I recently upgraded the factory deck in my 2004 Silverado (4 speakers, NOT the bose stereo). I used the harness which relocates the factory deck, and maintains all the functions annoyingly controled by the factory unit.
It all went very smoothly, and was very easy to wire the aftermarket deck into the add-on harness. The problem that I've run into is that there is no sound coming from the left front speaker. The right front and rear speakers work fine. I've checked and double checked my wiring with no success, all seems to be correct.  Also, if i pop a CD into the relocated factory deck, the problem is reversed. The right front speaker is dead and the left front and rear speakers work fine.
Anyone have any idea what may be causing this problem?
jettagli03
Copper - Posts: 311
Posted: January 21, 2005 at 8:45 PM / IP Logged
haha thats crazy, i've never seen that before (i havent been around too long as im only barely 17 btw). i would reccomend checking this site for wiring diagrams and see if theres more than one and maybe theres something there.. best of luck to ya
wheelerdr
Copper - Posts: 337
Posted: January 22, 2005 at 12:48 AM / IP Logged
It sound like this may be from the deck,
Chopndroptx
Member - Posts: 17
Posted: January 22, 2005 at 1:42 AM / IP Logged
Kinda sounds like something to do with the wiring to me.Maybe something to do with the antenna turn on,or the amp turn on.Did you hook up these wires at all?
Chris- Kenwood KDC-MP522,2pr-INI 6000CS's,Alpine MRPF240,Viper D1200.1,2-Soundstream VGW-12's
98 Nissan Frontier Minitruck
Houston,TX
Chopndroptx
Member - Posts: 17
Posted: January 22, 2005 at 1:45 AM / IP Logged
Nevermind i read that wrong.But still seems to be the wiring to me.Try using the GMRC01 from Circuit City!
Houston,TX
rviper488
Posted: January 22, 2005 at 9:47 AM / IP Logged
Thanks for the help guys, this problem has really got me stumped. I've ruled out the deck by changing it out with an old one I've got laying around, which produced the same results. The antenna turn on and amp turn on are not hooked up at all. It's a fairly basic setup, just an aftermarket deck wired into factory speakers. It's my work truck so I can't really do any major mods to it, I'm just trying to put a Mp3 deck in so I don't have to swap CD's several times a day.
All the wires are labeled clearly, both from the aftermarket deck, and from the relocation harness. Could a problem like this occur if the wires were labeled incorrectly for the left front speaker? Like if somehow + and - were reversed somewhere in the harness? If I were to attempt to switch the + and - from for the speaker from the deck to the harness would I run any risk of blowing the speaker?
Chopndroptx
Member - Posts: 17
Posted: January 22, 2005 at 10:11 AM / IP Logged
Having the + and - backwards would not cause this.It would only throw your speakers out of phase, then your speakers wouldnt sound good at all.
If you get the MET-GMRC01 you should be good,you dont even have to relocate your factory stereo.
Im thinking its got to do with the harness that you bought.
Houston,TX
